- To:
- Subject: [cgal-discuss] Re: error C2662 in creating a surface class for surface meshing
- Date: Sat, 16 Feb 2013 16:55:05 -0800 (PST)
Hi Philipp,
Thanks for the reply. Can you please clarify this statement?
> The code in question is simply missing the const qualification for
> MeshSurface::construct_initial_points_object.
I am not sure which object you are are referring to here. Are you referring
to the one declared on line 94/95 of the file make_surface_mesh.h or the one
on line 179/180 in the same file? Or may be I am completely off the chart
here. Thanks.
Regards,
Piyush Gupta
Piyush Gupta
UIUC
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/error-C2662-in-creating-a-surface-class-for-surface-meshing-tp951257p4656743.html
- [cgal-discuss] Re: error C2662 in creating a surface class for surface meshing, gupta61, 02/17/2013
- Re: [cgal-discuss] Re: error C2662 in creating a surface class for surface meshing, Philipp Moeller, 02/17/2013
