cgal-discuss - Re: [cgal-discuss] Re: error C2662 in creating a surface class for surface meshing
  • To: gupta61 <>
  • Cc:
  • Subject: Re: [cgal-discuss] Re: error C2662 in creating a surface class for surface meshing
  • Date: Sun, 17 Feb 2013 14:46:57 +0100
gupta61
writes:
> Hi Philipp,
> Thanks for the reply. Can you please clarify this statement?
>> The code in question is simply missing the const qualification for
>> MeshSurface::construct_initial_points_object.
> I am not sure which object you are are referring to here. Are you referring
> to the one declared on line 94/95 of the file make_surface_mesh.h or the one
> on line 179/180 in the same file? Or may be I am completely off the chart
> here. Thanks.
I was referring to the code sample posted by the OP. Maybe I am confused
about what you expect something to be followed up. Maybe you should open
a new thread with your specific problem.
