cgal-discuss - Re: [cgal-discuss] How to fixed the error of "request for member ‘*’ in ‘*’, which is of non-class type ‘const char [11]’ "
  • To:
  • Subject: Re: [cgal-discuss] How to fixed the error of "request for member ‘*’ in ‘*’, which is of non-class type ‘const char [11]’ "
  • Date: Wed, 20 Feb 2013 14:11:50 +0800
Hi, Laurent,
     Thanks for your reply.   Yes, you are right. I have changed the codes, so which can work well now.
template<class GT >
Geomview_stream&
operator<<( Geomview_stream &gv, const Structure_quadrangulation_2<GT> & quad)
    bool ascii_bak = gv.get_ascii_mode();
    bool raw_bak = gv.set_raw(true);
    show_quad(gv, quad);
    gv.set_raw(raw_bak);
    gv.set_ascii_mode(ascii_bak);
    return gv;
Best
Huayi
2013/2/19 Laurent Rineau (CGAL/GeometryFactory) <>
> template<class SQuad >
> Geomview_stream&
> operator<<( Geomview_stream &gv, const SQuad & quad)
That overload of operator<< matches everything for its second argument. That
overrides even the operator<<(Geomview_stream, const char*), and that causes
the error message.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
