[cgal-discuss] How to fixed the error of "request for member ‘*’ in ‘*’, which is of non-class type ‘const char [11]’ "
- To:
- Subject: [cgal-discuss] How to fixed the error of "request for member ‘*’ in ‘*’, which is of non-class type ‘const char [11]’ "
- Date: Tue, 19 Feb 2013 21:42:14 +0800
Hi, there,
I write a template function to use Geomview_stream to show a structure quad mesh.
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Structure_quadrangulation_2<K> Grid_2;
Grid_2 strgrid;
gv<<strgrid;
But there exist some errors when I compile it:
" request for member ‘rows’ in ‘quad’, which is of non-class type ‘const char [11]’ "
"request for member ‘cols’ in ‘quad’, which is of non-class type ‘const char [11]’ "
But for my structure quad mesh class, it has 'rows()' and 'cols()' as its memeber functions. Please help me to fix it. Thanks.
Best
Huayi
PS: the following code is the my Geomview_stream code:
template<class SQuad >
void
show_quad(Geomview_stream &gv,const SQuad & quad)
// Header.
gv.set_ascii_mode();
gv << "( geometry " << gv.get_new_id("quadrangulation")
<< "{ appearance { linewidth "
<< gv.get_line_width()<<" "<<"+edge"<<" "<<"-face"
<<" }{MESH \n"
<< quad.cols() <<"\t"<< quad.rows()<<"\n";
for(int i = 0; i < quad.rows(); i++)
for(int j = 0; j < quad.cols(); j++)
gv<<quad.point(i,j)<<"\t";
gv<<"\n";
// Footer.
gv << "}})";
Geomview_stream&
operator<<( Geomview_stream &gv, const SQuad & quad)
bool ascii_bak = gv.get_ascii_mode();
bool raw_bak = gv.set_raw(true);
show_quad(gv, quad);
gv.set_raw(raw_bak);
gv.set_ascii_mode(ascii_bak);
return gv;
- [cgal-discuss] How to fixed the error of "request for member ‘*’ in ‘*’, which is of non-class type ‘const char [11]’ ", 魏华祎, 02/19/2013
- Re: [cgal-discuss] How to fixed the error of "request for member ‘*’ in ‘*’, which is of non-class type ‘const char [11]’ ", Laurent Rineau (CGAL/GeometryFactory), 02/19/2013
