- To:
- Subject: Re: [cgal-discuss] Bollean operation error
- Date: Wed, 20 Feb 2013 15:40:59 +0100
Thanks for the reply Sebastien.
I was unaware of that constructor. Am I right in understanding that it only works with the Homogeneous kernel? That's what I understand from the documentation. The reason I ask is that all my code uses Exact_predicates_exact_constructions kernel.
The result not being simple is not a problem for me. I itterate through the volumes creating new nefs for each one.
2013/2/20 Sebastien Loriot (GeometryFactory) <>
Hi Noel,
you got a self-intersection in design.off.
Using CGAL::OFF_to_nef_3 to create the nef polyhedron gave a result,
but then the difference is not simple.
Sebastien--
On 02/20/2013 01:10 PM, Noel Warren wrote:
I get the following error when subtracting two Nef polyhedra
ERROR: CGAL ERROR: assertion violation!
Expr: itl != it->second.end()
File: /usr/local/include/CGAL/Nef_3/SNC_external_structure.h
Line: 1102
I have attatched the polyhedra in "off" format. They convert fine to
Nef_polyhedron_3. I have also tried the operation with the "Operations
on Polyhedra" demo. Performing the difference operation (stock -
design) also crashes it.
Thanks in advance.
- [cgal-discuss] Bollean operation error, Noel Warren, 02/20/2013
- Re: [cgal-discuss] Bollean operation error, Sebastien Loriot (GeometryFactory), 02/20/2013
- Re: [cgal-discuss] Bollean operation error, Noel Warren, 02/20/2013
