cgal-discuss - Re: [cgal-discuss] Bollean operation error
  • To:
  • Subject: Re: [cgal-discuss] Bollean operation error
  • Date: Wed, 20 Feb 2013 16:49:31 +0100
That's brilliant Sebastien
I wish I had known about that constructor from the start.  Is there some way of generating OFF files from Nefs without first converting them to polyhedra?  If I could avoid using the Polyhedron_3 class altogether it could make my code substatially "lighter".  Thanks again.
2013/2/20 Sebastien Loriot (GeometryFactory) <>
On 02/20/2013 03:40 PM, Noel Warren wrote:
Thanks for the reply Sebastien.
I was unaware of that constructor.  Am I right in understanding that it
only works with the Homogeneous kernel?
No, it also works with EPEC kernel.
Sebastien.
That's what I understand from
the documentation.  The reason I ask is that all my code uses
Exact_predicates_exact_constructions kernel.
The result not being simple is not a problem for me.  I itterate through
the volumes creating new nefs for each one.
<mailto:>>
    Hi Noel,
    you got a self-intersection in design.off.
    Using CGAL::OFF_to_nef_3 to create the nef polyhedron gave a result,
    but then the difference is not simple.
    Sebastien
    On 02/20/2013 01:10 PM, Noel Warren wrote:
        I get the following error when subtracting two Nef polyhedra
        ERROR: CGAL ERROR: assertion violation!
        Expr: itl != it->second.end()
        File: /usr/local/include/CGAL/Nef_3/__SNC_external_structure.h
        Line: 1102
        I have attatched the polyhedra in "off" format.  They convert
        fine to
        Nef_polyhedron_3.  I have also tried the operation with the
        "Operations
        on Polyhedra" demo.  Performing the difference operation (stock -
        design) also crashes it.
        Thanks in advance.
    https://sympa.inria.fr/sympa/__info/cgal-discuss
    <https://sympa.inria.fr/sympa/info/cgal-discuss>
