cgal-discuss - Re: [cgal-discuss] CGAL disables exception handling in MingW
  • To:
  • Subject: Re: [cgal-discuss] CGAL disables exception handling in MingW
  • Date: Tue, 26 Feb 2013 11:20:35 +0100
Le mardi 26 février 2013 10:13:32 Dragan Vidovic a écrit :
> Exception handling stops working in my C++ program if I link it with
> CGAL in MingW, even if no CGAL code is executed. If CGAL is removed,
> exception handling works fine. In Linux everything works fine. I tried
> adding the -mthreads options to the compiler and to the linker while
> building CGAL and my program, but this did not change anything. I
> noticed this problem with CGAL-3.9 and CGAL-4.1 using boost_1_46_0 or
> boost_1_53_0. Compiler version is 4.6.2.
That issue will probably be difficult to debug.
Can you please show us a simple .cpp that compiles with MinGW, uses exceptions correctly, and no longer runs correctly once CGAL libraries are linked with the executable? I will use that to try to reproduce and debug.
Have you use the same version of the compiler to build the CGAL libraries?
Laurent Rineau, PhD
