cgal-discuss - [cgal-discuss] CGAL disables exception handling in MingW
  • To:
  • Subject: [cgal-discuss] CGAL disables exception handling in MingW
  • Date: Tue, 26 Feb 2013 10:13:32 +0100
Exception handling stops working in my C++ program if I link it with
CGAL in MingW, even if no CGAL code is executed. If CGAL is removed,
exception handling works fine. In Linux everything works fine. I tried
adding the -mthreads options to the compiler and to the linker while
building CGAL and my program, but this did not change anything. I
noticed this problem with CGAL-3.9 and CGAL-4.1 using boost_1_46_0 or
boost_1_53_0. Compiler version is 4.6.2.
