cgal-discuss - Re: [cgal-discuss] Re: Rounding mode (as specified in FPU.h)
  • To:
  • Subject: Re: [cgal-discuss] Re: Rounding mode (as specified in FPU.h)
  • Date: Thu, 28 Feb 2013 22:22:57 +0100 (CET)
On Thu, 28 Feb 2013, marcosscriven wrote:
Thanks again for your input - its clear I need to spend some time really
understanding CGAL. :) I don't really use it directly, but via another piece
of software that uses it for boolean operations on meshes.
I was hoping there might be a quick fix/macro I could just set on the
compiler and voila!
One point I maybe should have stressed: these operations with specific rounding modes are there as optimizations. If you don't care about performance, using a kernel like Simple_cartesian<Gmpq> should work and not use any floating point (no problem with rounding then). I say "should" because I don't know anything about the boolean operation package.
Marc Glisse
