- To:
- Subject: [cgal-discuss] Calculate Hausdorff distance between two meshes
- Date: Thu, 28 Feb 2013 14:07:15 -0800 (PST)
Hi,
i am trying to find the deviation between two meshes. For e.g. the
difference between two sets of points defined in 3d space, and i plan to
visualise the distance using some 3d visualisation tool for e.g. QT3d or
some open gl based library.
I have two sets of meshes, basically two .stl files. I have programmed to
read them as inputs. Now I need to calculate the deviation between the
corresponding meshes. For this, I understand that the Hausdorff distance is
a possible mathematical tool. Is it currently possible in CGAL to calculate
the Hausdorff distance between two meshes?
i managed to find one piece of code. but its more or less a programm in
itself. its called M.E.S.H. I dont want to use it as it is because, 1. its
written in C, 2. I want to develop my own application (using a library of
course).
The other questions asked on this forum are pointing towards the
mathematical algorithm, I dont plan to implement the algorithm on my own.
I am using QT5 for programming with msvc2010(32 bit).
Best Regards
tdk.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Calculate-Hausdorff-distance-between-two-meshes-tp4656808.html
- [cgal-discuss] Calculate Hausdorff distance between two meshes, thedorkknight, 02/28/2013
