- To:
- Subject: [cgal-discuss] Re: Precompiled ipelets or how to compile them?
- Date: Tue, 5 Mar 2013 10:39:14 +0100
configuration is successful and solution is build by cmake:
This is the Windows CMake running within the cygwin platform.
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
USING EXEFLAGS = ' /STACK:10000000 /machine:X86 /INCREMENTAL:NO'
Targetting Visual Studio 10
Target build enviroment supports auto-linking
Using VC10 compiler.
Generator uses intermediate configuration directory: $(Configuration)
Requested component: Core
Requested component: IPE
Found Ipe: C:\Programs\ipe-7.0.10\include C:\Programs\ipe-7.0.10\bin\ipe.dll
Requested component: MPFR
Requested component: GMP
-- Using IPE version 7 compatibility.
Configuring done
========================================ThanksPrecompiled binaries would be much appreciated, also.As I can't find any instructions how to build these ipelets, I thought to use this mailing list.Reading ipelets documentation, suggests that library that's needed for ipelet to be compiled is ipe.dll. This file exists in folder pointed by IPE_LIBRARIES env var.- IPE_LIBRARIES pointing to "bin" folder from my Ipe installation, which is not recognized.I made additional env vars:Hi,I compiled latest CGAL on 32bit Windows. Everything went smooth by following instructions linked from CGAL portal.
Now I wanted to compile CGAL ipelets, provided as demo package.
- IPE_INCLUDE_DIR pointing to "include" folder from my Ipe installation, which is correctly recognized by CMake
- [cgal-discuss] Precompiled ipelets or how to compile them?, klo uo, 03/04/2013
- [cgal-discuss] Re: Precompiled ipelets or how to compile them?, klo uo, 03/05/2013
- Re: [cgal-discuss] Re: Precompiled ipelets or how to compile them?, Sebastien Loriot (GeometryFactory), 03/05/2013
- Re: [cgal-discuss] Re: Precompiled ipelets or how to compile them?, klo uo, 03/05/2013
- [cgal-discuss] Re: Precompiled ipelets or how to compile them?, klo uo, 03/06/2013
- Re: [cgal-discuss] Re: Precompiled ipelets or how to compile them?, Sebastien Loriot (GeometryFactory), 03/06/2013
- Re: [cgal-discuss] Re: Precompiled ipelets or how to compile them?, klo uo, 03/06/2013
