- To:
- Subject: [cgal-discuss] error in configuring cgal
- Date: Tue, 5 Mar 2013 18:00:19 +0530
- cgal-4.1
- cmake 2.8.8
- boost_1_47
- qt 4.8.4
- Visual Studio 9 on windows 7
Check for working CXX compiler using: Visual Studio 9 2008 Win64
Check for working CXX compiler using: Visual Studio 9 2008 Win64 -- broken
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/CMakeTestCXXCompiler.cmake:45 (MESSAGE):
The C++ compiler "cl" is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/Program Files (x86)/CGAL-4.1/CMakeFiles/CMakeTmp
Run Build Command:C:\PROGRA~2\MICROS~1.0\Common7\IDE\devenv.com
CMAKE_TRY_COMPILE.sln /build Debug /project cmTryCompileExec966084484
Microsoft (R) Visual Studio Version 9.0.21022.8.
Copyright (C) Microsoft Corp. All rights reserved.
The project consists entirely of configurations that require support for
platforms which are not installed on this machine. The project cannot be
loaded.
loaded.
Invalid project
Use:
devenv [solutionfile | projectfile | anyfile.ext] [switches]
The first argument for devenv is usually a solution file or project file.
You can also use any other file as the first argument if you want to have
the
file open automatically in an editor. When you enter a project file, the
IDE
looks for an .sln file with the same base name as the project file in the
parent directory for the project file. If no such .sln file exists, then
the
IDE looks for a single .sln file that references the project. If no such
single
.sln file exists, then the IDE creates an unsaved solution with a default
.sln
file name that has the same base name as the project file.
Command line builds:
devenv solutionfile.sln /build [ solutionconfig ] [ /project
projectnameorfile [ /projectconfig name ] ]
Available command line switches:
/Build Builds the solution or project with the specified solution
configuration. For example "Debug". If multiple platforms
are possible, the configuration name must be enclosed in quotes
and contain platform name. For example: "Debug|Win32".
/Clean Deletes build outputs.
/Command Starts the IDE and executes the command.
/Deploy Builds and then deploys the specified build configuration.
/Edit Opens the specified files in a running instance of this
application. If there are no running instances, it will
start a new instance with a simplified window layout.
/LCID Sets the default language in the IDE for the UI.
/Log Logs IDE activity to the specified file for troubleshooting.
/NoVSIP Disables the VSIP developer's license key for VSIP testing.
/Out Appends the build log to a specified file.
/Project Specifies the project to build, clean, or deploy.
Must be used with /Build, /Rebuild, /Clean, or /Deploy.
/ProjectConfig Overrides the project configuration specified in the
solution
configuration. For example "Debug". If multiple platforms are
Must be used with /Project.
/Rebuild Cleans and then builds the solution or project with the
specified configuration.
/ResetAddin Removes commands and command UI associated with the specified
Add-in.
/ResetSettings Restores the IDE's default settings, optionally resets to
the specified VSSettings file.
/ResetSkipPkgs Clears all SkipLoading tags added to VSPackages.
/Run Compiles and runs the specified solution.
/RunExit Compiles and runs the specified solution then closes the IDE.
/SafeMode Launches the IDE in safe mode loading minimal windows.
/Upgrade Upgrades the project or the solution and all projects in it.
A backup of these files will be created as appropriate. Please
see Help on 'Visual Studio Conversion Wizard' for more
information on the backup process.
Product-specific switches:
/debugexe Open the specified executable to be debugged. The
remainder of the command line is passed to this
executable as its arguments.
/useenv Use PATH, INCLUDE, LIBPATH, and LIB environment variables
instead of IDE paths for VC++ builds.
To attach the debugger from the command line, use:
VsJITDebugger.exe -p <pid>
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:6 (project)
Configuring incomplete, errors occurred!
- [cgal-discuss] error in configuring cgal, Subramaniam Thirunavukkarasu, 03/05/2013
