Re: [cgal-discuss] h->opposite()->facet() always invalid using Polyhedron_incremental_builder_3
- To:
- Subject: Re: [cgal-discuss] h->opposite()->facet() always invalid using Polyhedron_incremental_builder_3
- Date: Wed, 06 Mar 2013 06:37:07 +0100
Can you give more information like the modifier you wrote for example?
A common mistake is not reusing the vertices. If you add two vertices
with the same coordinates, they will be consider as different.
Sebastien.
On 03/06/2013 05:51 AM, Evan Behar wrote:
I have constructed a Polyhedron_3, /P/, using the
Polyhedron_incremental_builder_3, and I am running into the problem that
none of the halfedges in the structure are being associated with any
opposite halfedges that have been previously constructed.
After construction, retrieving a Halfedge_handle /h/ from /P /and
calling /h->opposite()->facet()/ always results in an invalid Facet_handle.
Is this expected behavior from Polyhedron_incremental_builder_3? Do I
have to stitch the facets together manually?
- [cgal-discuss] h->opposite()->facet() always invalid using Polyhedron_incremental_builder_3, Evan Behar, 03/06/2013
- Re: [cgal-discuss] h->opposite()->facet() always invalid using Polyhedron_incremental_builder_3, Sebastien Loriot (GeometryFactory), 03/06/2013
- Re: [cgal-discuss] h->opposite()->facet() always invalid using Polyhedron_incremental_builder_3, Evan Behar, 03/06/2013
