cgal-discuss - Re: [cgal-discuss] h->opposite()->facet() always invalid using Polyhedron_incremental_builder_3
  • To:
  • Subject: Re: [cgal-discuss] h->opposite()->facet() always invalid using Polyhedron_incremental_builder_3
  • Date: Wed, 06 Mar 2013 06:56:24 +0100
The code looks OK.
Do you call delegate several times on the same polyhedron?
Having an example I can compile and run would be nice as I have no other idea for now.
Sebastien.
On 03/06/2013 06:43 AM, Evan Behar wrote:
I am loading the model from an OBJ file--first I read in the vertices
and facets from the OBJ file and then I am constructing the polyhedron
using those values. I add the vertices all at once and then construct
the facets using the vertex indices, so I am almost certainly reusing
the vertices. The modifier code is below:
class Build_polyhedron : public
CGAL::Modifier_base<Polyhedron::HalfedgeDS> {
public:
Build_polyhedron() {}
void operator()(Polyhedron::HalfedgeDS& hds) {
CGAL::Polyhedron_incremental_builder_3<Polyhedron::HalfedgeDS>
builder(hds,true);
const std::vector<Point>& vertices = OBJReader::vertices;
const std::vector<std::vector<int> >& facets = OBJReader::facets;
builder.begin_surface(vertices.size(),facets.size());
// add vertices
for (int i=0;i<vertices.size();i++) {
builder.add_vertex(vertices[i]);
// add facets
for (int i=0;i<facets.size();i++) {
builder.begin_facet();
for (int j=0;j<facets[i].size();j++) {
builder.add_vertex_to_facet(facets[i][j]);
Halfedge_handle h = builder.end_facet();
std::cout << "Validating...\n";
if (h->opposite()->facet() != Facet_handle()) {
std::cout << "Opposite halfedge's facet not invalid!\n";
builder.end_surface();
On Wed, Mar 6, 2013 at 12:37 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
Can you give more information like the modifier you wrote for example?
A common mistake is not reusing the vertices. If you add two vertices
with the same coordinates, they will be consider as different.
Sebastien.
On 03/06/2013 05:51 AM, Evan Behar wrote:
I have constructed a Polyhedron_3, /P/, using the
Polyhedron_incremental___builder_3, and I am running into the
problem that
none of the halfedges in the structure are being associated with any
opposite halfedges that have been previously constructed.
After construction, retrieving a Halfedge_handle /h/ from /P /and
calling /h->opposite()->facet()/ always results in an invalid
Facet_handle.
Is this expected behavior from
Polyhedron_incremental___builder_3? Do I
have to stitch the facets together manually?
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
