cgal-discuss - [cgal-discuss] Re: Timings for mesh generation
  • To:
  • Subject: [cgal-discuss] Re: Timings for mesh generation
  • Date: Wed, 13 Mar 2013 09:31:10 -0700 (PDT)
To compile the CGAL libraries I used all the default settings.
To compile the mesh_polyhedral_domain example I ran cmake on the
CMakeLists.txt provided with the example and then ran make on the generated
makefile. Buried deep in the cmakefiles directory, I have found the
following options for mesh_polyhedral_domain:
CXX_FLAGS = -frounding-math -O3 -DNDEBUG (followed by several include
directories)
CXX_DEFINES = -DCGAL_MESH_3_NO_DEPRECATED_SURFACE_INDEX
-DCGAL_MESH_3_NO_DEPRECATED_C3T3_ITERATORS
link.txt appears as follows: /usr/bin/c++ -frounding-math -O3 -DNDEBUG
CMakeFiles/mesh_polyhedral_domain.dir/mesh_polyhedral_domain.o -o
mesh_polyhedral_domain -rdynamic -L/usr/local/lib /usr/local/lib/libCGAL.so
/usr/local/lib/libmpfr.so /usr/local/lib/libgmp.so
/usr/local/lib/libboost_thread.so /usr/local/lib/libCGAL.so
/usr/local/lib/libboost_thread.so -Wl,-rpath,/usr/local/lib
Let me know if there is anything more one must know to make a fair
assessment of what has affected the running time. Thanks again.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Timings-for-mesh-generation-tp4656932p4656944.html
