cgal-discuss - Re: [cgal-discuss] Re: h.has_on(p) assertion error - how to figure out why?
  • To:
  • Subject: Re: [cgal-discuss] Re: h.has_on(p) assertion error - how to figure out why?
  • Date: Fri, 15 Mar 2013 22:24:22 +0100 (CET)
On Fri, 15 Mar 2013, marcosscriven wrote:
After an awful lot of experimenting with LLVM opt settings, I found the cause
of this issue to be the 'early-cse' optimisation pass.
I can't find a straight forward explanation of what the pass does however.
It would be more interesting to reduce the size of the code. cse usually looks for redundant computations and eliminates one of them. A typical issue is when it sees a+b (rounded up) and a+b (rounded down) and since it knows nothing about rounding it assumes they are the same and computes only one. However, sensitive code in CGAL is protected against this (using volatile or inline asm so llvm doesn't know it is the same 'a' in both operations). Many different kinds of issues (unrelated to rounding) could be revealed by cse, and unless you know which piece of code is misoptimized, it is hard to say anything.
Marc Glisse
