cgal-discuss - Re: [cgal-discuss] Re: h.has_on(p) assertion error - how to figure out why?
  • To:
  • Subject: Re: [cgal-discuss] Re: h.has_on(p) assertion error - how to figure out why?
  • Date: Mon, 11 Mar 2013 16:09:37 +0100
I see. You can use Simple_cartesian<Gmpq> and the stream operator directly on a nef polyhedron.
Sebastien.
On 03/11/2013 04:06 PM, marcosscriven wrote:
Hi Sebastien
Thanks - the trouble I have is that the inputs to CGAL at the time of the
assertion failure are mid way through a complex CSG tree.
Are the any convenience methods to stringify a Nef_polyhedron_3, or
otherwise output it's full state?
That way I could just print to the console the two polyhedrons causing this
issue, then create a test case to just take the difference of the two.
Marcos
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/h-has-on-p-assertion-error-how-to-figure-out-why-tp4656866p4656902.html
