- To:
- Subject: Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2
- Date: Thu, 28 Mar 2013 11:31:35 +0100
Le mercredi 27 mars 2013 23:17:14 Philipp Blanke a écrit :
> Hello!
> I think I found an error in the description of the Segment_Delaunay_graph_2
> on
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Segment_Delaunay_grap
> h_2_ref/Class_Segment_Delaunay_graph_2.html
> Looking at the code, i find that Segment_Delaunay_graph_2 is templated by
> 4 parameters, not two as described (which gave me a headache):
> CGAL::Segment_Delaunay_graph_
> 2<
> Gt, // geometric traits
> St, // storage traits
> TDS, // triangulation data structure
> LTag // don't know what that is for
The last two template parameters have defaults, and are not documented.
In which scenario do you need to know that CGAL::Segment_Delaunay_graph_2 is
a
class template with four parameters?
Laurent Rineau, PhD
- [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Philipp Blanke, 03/27/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Laurent Rineau (CGAL/GeometryFactory), 03/28/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Philipp Blanke, 03/29/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, xiaojing xuan, 03/29/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Sebastien Loriot (GeometryFactory), 03/29/2013
