- To:
- Subject: Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2
- Date: Fri, 29 Mar 2013 15:48:00 +0100
On 03/29/2013 02:53 PM, Philipp Blanke wrote:
Hello!Could you send a screenshot in a private email?
I was unclear in my problem statement. The doc says
Segment_Delaunay_graph_2<Gt, DS>
while the source says
Segment_Delaunay_graph_2<Gt, ST, DS, LTag>
There are defaults for the last three values, but the order is wrong.
I just needed to change the TDS, so it accomodates info() for
vertices. Doing it after the doc gave me errors of course. I then also
had to give the (default) storage traits, since I did not want to
touch the source.
By the way, I just discovered the new doxygen docs. Nice work. I
appreciate the menu on the left! In my browser (Firefox 19) all text
is rendered bold. Intentional?
Thanks,
Sebastien.
Best,
Philipp
On Thu, Mar 28, 2013 at 11:31 AM, Laurent Rineau
(CGAL/GeometryFactory)<>
wrote:
Le mercredi 27 mars 2013 23:17:14 Philipp Blanke a écrit :
Hello!
I think I found an error in the description of the Segment_Delaunay_graph_2
on
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Segment_Delaunay_grap
h_2_ref/Class_Segment_Delaunay_graph_2.html
Looking at the code, i find that Segment_Delaunay_graph_2 is templated by
4 parameters, not two as described (which gave me a headache):
CGAL::Segment_Delaunay_graph_
2<
Gt, // geometric traits
St, // storage traits
TDS, // triangulation data structure
LTag // don't know what that is for
The last two template parameters have defaults, and are not documented.
In which scenario do you need to know that CGAL::Segment_Delaunay_graph_2 is a
class template with four parameters?
Laurent Rineau, PhD
Philipp
Blanke<>
| Fon: +49 (0)5 11-762 29 13
| Fax: +49 (0)5 11-762 29 11
Leibniz Universität Hannover | Jabber:
Welfenlab - Division of Computer Graphics | ICQ: 275577053
Welfengarten 1, D-30167 Hannover | http://www.welfenlab.de
- [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Philipp Blanke, 03/27/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Laurent Rineau (CGAL/GeometryFactory), 03/28/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Philipp Blanke, 03/29/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, xiaojing xuan, 03/29/2013
- Re: [cgal-discuss] Error in documentation of Segment_Delaunay_graph_2, Sebastien Loriot (GeometryFactory), 03/29/2013
