cgal-discuss - Re: [cgal-discuss] exact precision, affine transformations, and newell's method
  • To: "" <>
  • Subject: Re: [cgal-discuss] exact precision, affine transformations, and newell's method
  • Date: Sat, 30 Mar 2013 16:05:12 -0700
Marc,
Thank you for your reply. Given that they do, in fact, point the same
direction, do you know why CGAL is considering them unequal? Equality in this
case is, as I understand it, the entire reason you would use directions
instead of vectors.
I will contact you directly later today regarding your number type.
Thanks,
Cody
On Mar 30, 2013, at 6:59 AM, Marc Mörig
wrote:
> Dear Cody,
> the resulting normals in your example are linearly dependend, i.e. do point
> in the same direction. Even if Newells method returns a normalized vector
> (I don't know ...) the affine transformation may change its length.
> Btw: I would still be very interested in comparing the performance of
> leda::real and Core::Expr to my number type within your application.
> Regards,
> Marc Mörig
> On 29.03.2013 23:11, Cody Rose wrote:
>> Hello,
>> I've stumbled into some CGAL behavior I can't explain and I was hoping
>> that someone could help me understand it. In my application, I'm using
>> Newell's method to calculate the approximate normal for a polygon-like
>> series of points (http://cs.haifa.ac.il/~gordon/plane.pdf). (The idea is
>> that if all the points are actually coplanar, it will yield the true
>> normal, but if they aren't quite, it will give a "best fit.") The
>> problem I'm having is essentially this, given a particular affine
>> transformation T and the kernel Cartesian<leda_real>:
>> newell(T(points)) != T(newell(points))
>> And I can't figure out why not, since I was under the impression that
>> this kernel is exact (and that this should work in an exact kernel). I
>> can't chalk it up to variations in how Newell's method approximates a
>> plane fit before and after the transformation, because in the example I
>> attached, all the points are actually coplanar after all. (Honestly that
>> explanation wouldn't make sense to me anyway.)
>> So I feel like I'm missing something about the way exactness (or this
>> affine transformation) works. Can anyone clear this up?
>> Cody Rose
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
