- To:
- Subject: [cgal-discuss] exact precision, affine transformations, and newell's method
- Date: Fri, 29 Mar 2013 15:11:37 -0700
Hello,
I've stumbled into some CGAL behavior I can't explain and I was hoping that someone could help me understand it. In my application, I'm using Newell's method to calculate the approximate normal for a polygon-like series of points (http://cs.haifa.ac.il/~gordon/plane.pdf). (The idea is that if all the points are actually coplanar, it will yield the true normal, but if they aren't quite, it will give a "best fit.") The problem I'm having is essentially this, given a particular affine transformation T and the kernel Cartesian<leda_real>:
newell(T(points)) != T(newell(points))
And I can't figure out why not, since I was under the impression that this kernel is exact (and that this should work in an exact kernel). I can't chalk it up to variations in how Newell's method approximates a plane fit before and after the transformation, because in the example I attached, all the points are actually coplanar after all. (Honestly that explanation wouldn't make sense to me anyway.)
So I feel like I'm missing something about the way exactness (or this affine transformation) works. Can anyone clear this up?
Cody Rose
#define CGAL_USE_LEDA
#define CGAL_LEDA_VERSION 630
#define LEDA_DLL
#include <vector>
#include <cstdio>
#include <CGAL/leda_real.h>
#include <CGAL/Cartesian.h>
typedef leda_real NT;
typedef CGAL::Cartesian<NT> K;
typedef CGAL::Direction_3<K> direction_3;
typedef CGAL::Point_3<K> point_3;
typedef CGAL::Aff_transformation_3<K> transformation_3;
direction_3 newell(const std::vector<point_3> & loop) {
NT a(0.0), b(0.0), c(0.0);
for (size_t i = 0; i < loop.size(); ++i) {
auto & curr = loop[i];
auto & next = loop[(i+1) % loop.size()];
a += (curr.y() - next.y()) * (curr.z() + next.z());
b += (curr.z() - next.z()) * (curr.x() + next.x());
c += (curr.x() - next.x()) * (curr.y() + next.y());
return direction_3(a, b, c);
int main() {
transformation_3 t(0.00000000000000000, -0.97175545666443730,
0.23599011090062880, -6363.1356980000000,
1.0000000000000000,
0.00000000000000000, 0.00000000000000000, 871.99942999999996,
0.23599011090062882, 0.97175545666443719, 216.00000000000000);
// These points are all coplanar...
std::vector<point_3> v;
v.push_back(point_3(0, 0, 0));
v.push_back(point_3(1, 0, 0));
v.push_back(point_3(1, 1, 0));
v.push_back(point_3(0, 1, 0));
/// so normal_before = <0, 0, 1>.
direction_3 normal_before = newell(v);
for (auto p = v.begin(); p != v.end(); ++p) { *p = t(*p); }
direction_3 normal_after = newell(v);
direction_3 transformed = t(normal_before);
if (t(normal_before) == normal_after) {
// This is what I expected to happen.
printf("equal!\n");
else {
// This is what actually happens!
printf("not equal!\n");
NT ddx = transformed.dx() - normal_after.dx();
NT ddy = transformed.dy() - normal_after.dy();
NT ddz = transformed.dz() - normal_after.dz();
if (CGAL::is_zero(ddx)) { printf("dx difference is zero\n"); }
else { printf("dx difference is %+2.25f\n",
CGAL::to_double(ddx)); }
if (CGAL::is_zero(ddy)) { printf("dy difference is zero\n"); }
else { printf("dy difference is %+2.25f\n",
CGAL::to_double(ddy)); }
if (CGAL::is_zero(ddz)) { printf("dz difference is zero\n"); }
else { printf("dz difference is %+2.25f\n",
CGAL::to_double(ddz)); }
return 0;
- [cgal-discuss] exact precision, affine transformations, and newell's method, Cody Rose, 03/29/2013
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Marc Mörig, 03/30/2013
- Re: [cgal-discuss] exact precision, affine transformations, and newell's method, Cody Rose, 03/31/2013
