- To:
- Subject: Re: [cgal-discuss] Re: Check whether two polyhedron_3 are intersection
- Date: Tue, 02 Apr 2013 07:13:26 +0200
On 04/01/2013 10:49 AM, sdg wrote:
Hi, thanks for your solution. I've tried the functionstd::list< std::vector<Point_3> > polylines;
intersection_Polyhedron_3_Polyhedron_3, but my compiler always throws
"instantiated from here" on this function.
The code I used
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Kernel::Point_3 Point_3;
std::vector<Point_3> polyline;
CGAL::intersection_Polyhedron_3_Polyhedron_3(poly1, poly2,> std::back_inserter(polylines));
std::back_inserter(polyline));
Sebastien.
std::cout<<polyline.size()<<std::endl;
What could be wrong?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Check-whether-two-polyhedron-3-are-intersection-tp4657064p4657093.html
- [cgal-discuss] Re: Check whether two polyhedron_3 are intersection, sdg, 04/01/2013
- Re: [cgal-discuss] Re: Check whether two polyhedron_3 are intersection, Sebastien Loriot (GeometryFactory), 04/02/2013
