cgal-discuss - Re: [cgal-discuss] exact precision, affine transformations, and newell's method
  • To:
  • Subject: Re: [cgal-discuss] exact precision, affine transformations, and newell's method
  • Date: Tue, 02 Apr 2013 07:21:43 +0200
On 03/30/2013 02:59 PM, Marc Mörig wrote:
Dear Cody,
the resulting normals in your example are linearly dependend, i.e. do
point in the same direction. Even if Newells method returns a normalized
vector (I don't know ...) the affine transformation may change its length.
Btw: I would still be very interested in comparing the performance of
leda::real and Core::Expr to my number type within your application.
What is "your number type"?
Sebastien.
Regards,
Marc Mörig
On 29.03.2013 23:11, Cody Rose wrote:
Hello,
I've stumbled into some CGAL behavior I can't explain and I was hoping
that someone could help me understand it. In my application, I'm using
Newell's method to calculate the approximate normal for a polygon-like
series of points (http://cs.haifa.ac.il/~gordon/plane.pdf). (The idea is
that if all the points are actually coplanar, it will yield the true
normal, but if they aren't quite, it will give a "best fit.") The
problem I'm having is essentially this, given a particular affine
transformation T and the kernel Cartesian<leda_real>:
newell(T(points)) != T(newell(points))
And I can't figure out why not, since I was under the impression that
this kernel is exact (and that this should work in an exact kernel). I
can't chalk it up to variations in how Newell's method approximates a
plane fit before and after the transformation, because in the example I
attached, all the points are actually coplanar after all. (Honestly that
explanation wouldn't make sense to me anyway.)
So I feel like I'm missing something about the way exactness (or this
affine transformation) works. Can anyone clear this up?
Cody Rose
