cgal-discuss - Re: [cgal-discuss] Re: Divide by Zero in AABB tree
  • To:
  • Subject: Re: [cgal-discuss] Re: Divide by Zero in AABB tree
  • Date: Mon, 08 Apr 2013 07:42:39 +0200
I don't know what the file you sent is.
What I wanted to see is the place in the code where is crashed
using the callstack in gdb (using 'where' command).
Also I suspect you have degenerated triangles which might lead
to this issue
Sebastien.
On 04/05/2013 04:25 AM, schrodingersnewcat wrote:
Linux 2.6.32-220.7.1.el6.x86_64
The AABB tree is tressP[3] and the query point is called query.
What else can I provide?
node3.core
<http://cgal-discuss.949826.n4.nabble.com/file/n4657123/node3.core>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Divide-by-Zero-in-AABB-tree-tp4657026p4657123.html
