- To:
- Subject: Re: [cgal-discuss] Implicit surface mesh with features
- Date: Mon, 08 Apr 2013 14:56:00 +0200
Hi Dave It is not currently possible to use the implicit surface mesher if you have sharp features. However you can use for that the tetrahedral mesher. The 3d mesh generator behaves as the surface mesher when it is launched with trivial criteria for the mesh tetrahedra. Besides it has the advantage to offer the possibility of handling sharp edges. Le 07/04/13 03:55, David Bernstein a
écrit :
Hi Everyone, Is it possible to use features in the implicit surface mesher? What I would like to do is mesh an implicit surface (a level set) and have the mesh respect a certain set of edges that are specified separately and known to be on the surface. I have looked through the manual quite a bit and can only find the one (two spheres) example for a 3D tetrahedral mesh. Thanks, Dave -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Implicit-surface-mesh-with-features-tp4657130.html Sent from the cgal-discuss mailing list archive at Nabble.com. -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Implicit surface mesh with features, David Bernstein, 04/07/2013
- Re: [cgal-discuss] Implicit surface mesh with features, Sebastien Loriot (GeometryFactory), 04/08/2013
- Re: [cgal-discuss] Implicit surface mesh with features, Mariette Yvinec, 04/08/2013
- [cgal-discuss] Re: Implicit surface mesh with features, David Bernstein, 04/08/2013
- Re: [cgal-discuss] Re: Implicit surface mesh with features, Clément Jamin, 04/09/2013
- [cgal-discuss] Re: Implicit surface mesh with features, David Bernstein, 04/12/2013
