cgal-discuss - Re: [cgal-discuss] Re: Implicit surface mesh with features
  • To:
  • Subject: Re: [cgal-discuss] Re: Implicit surface mesh with features
  • Date: Tue, 9 Apr 2013 10:53:30 +0200
On Mon, Apr 8, 2013 at 6:04 PM, David Bernstein
wrote:
> Mariette Yvinec wrote
>> Hi Dave
>> It is not currently possible to use the implicit surface mesher
>> if you have sharp features.
>> However you can use for that the tetrahedral mesher.
>> The 3d mesh generator behaves as the surface mesher
>> when it is launched with trivial criteria
>> for the mesh tetrahedra. Besides it has the advantage
>> to offer the possibility of handling sharp edges.
>> Mariette Yvinec
>> Geometrica project team
>> INRIA Sophia-Antipolis
> Hi Mariette, Thanks very much for your response. Can you elaborate on what
> is the "trivial criteria" for tetrahedra? Is it that they are degenerate,
> or triangles, so that only a surface mesh is created by calling the 3D
> mesher this way? If so, that would work fine for me. I would rather not
> have to create a full 3D mesh of tetrahedra and then extract the surface
> mesh (since for the application I have in mind this will most likely be too
> slow).
Hi,
Just don't specify any criteria for the cells, so that they don't get refined.
Then parse the facets of the C3T3 using the iterators
"facets_in_complex_begin" and "facets_in_complex_end", this will give
you the surface triangles
Hope this helps,
Clément Jamin.
