- To:
- Subject: Re: [cgal-discuss] Cut Polyhedron and close large hole.
- Date: Fri, 19 Apr 2013 09:30:34 +0200
The only documented way to do this is to use Nef_3 package to intersect
your mesh with an half-space.
See
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html
Sebastien.
On 04/17/2013 08:41 AM, mario wrote:
Hello,
i've a polyhedron coming out from a 3d surface reconstruction (Surface
reconstruction from point set package and
CGAL::output_surface_facets_to_polyhedron).
As triangulation is no good in top region of my particular shape, i'd like
to cut my polyhedron with a plane and close the resulting hole. Wich package
should i study to do that?
best regards, Mario
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Cut-Polyhedron-and-close-large-hole-tp4657210.html
- [cgal-discuss] Cut Polyhedron and close large hole., mario, 04/17/2013
- Re: [cgal-discuss] Cut Polyhedron and close large hole., Sebastien Loriot (GeometryFactory), 04/19/2013
