- To:
- Subject: Re: [cgal-discuss] Bounded Power Diagram
- Date: Fri, 19 Apr 2013 09:25:58 +0200
You can try this package which simulate a halfedge data structure to represent the diagram:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Voronoi_diagram_2/Chapter_main.html
If you need the diagram to be explicitely built, I have experimental
code that creates a hds and crop a Voronoi diagram to a rectangle [1].
It should work for a power diagram too.
Look at main.cpp in test directory.
Sebastien
[1] http://code.google.com/p/cgal-voronoi-cropping/
On 04/19/2013 09:13 AM, liudaisuda wrote:
Hey, guys. I am new to CGAL and didn't find any documentation to my question
below. Thanks in advance for you kind help.
I am trying to generate a bounded power diagram which could simply be done
by clipping the Power diagram with the boundary. However, this is not what I
am seeking. I need to compute for each power diagram cell within the
boundary the centroid. I could store each clipped power diagram cell in a
convex polygon structure, and then compute its centroid, but with this
approach I will have to build the power diagram from scratch, and thus make
no use of the nice features provided by CGAL. My question is, if is there
any way I can use structures such as constrained Delaunay Triangulation to
tackle this problem?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bounded-Power-Diagram-tp4657223.html
- [cgal-discuss] Bounded Power Diagram, liudaisuda, 04/19/2013
- Re: [cgal-discuss] Bounded Power Diagram, Sebastien Loriot (GeometryFactory), 04/19/2013
- [cgal-discuss] Re: Bounded Power Diagram, liudaisuda, 04/19/2013
- Re: [cgal-discuss] Re: Bounded Power Diagram, Sebastien Loriot (GeometryFactory), 04/29/2013
- Re: [cgal-discuss] Bounded Power Diagram, Olivier Devillers, 04/19/2013
