- To:
- Subject: [cgal-discuss] AccessViolation Exception in surface generation
- Date: Fri, 19 Apr 2013 01:34:47 -0700 (PDT)
Hi,
I am calling several time the Poisson surface reconstruction in my
application. Some times even with same point set my application crash with
this error "System.AccessViolation Exception: attempted to read or write
protected memory". Sometimes it happens and others time it's ok. It let me
think about not initialized pointers about poisson function.
I use CGAL 4.1 32 bit in windows builded with visualstudio 2010.
i tested my application in windows 7 32 and 64 bit editions.
I discovered that if i put my application setting to windowsxp compatibility
mode i solve and it never crashes!!
at this point this could already be a solution but could there be other
possibilities ?
Best Regards,
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/AccessViolation-Exception-in-surface-generation-tp4657227.html
- [cgal-discuss] AccessViolation Exception in surface generation, mario, 04/19/2013
- Re: [cgal-discuss] AccessViolation Exception in surface generation, Laurent Saboret, 04/19/2013
- [cgal-discuss] Re: AccessViolation Exception in surface generation, mario, 04/22/2013
- Re: [cgal-discuss] Re: AccessViolation Exception in surface generation, Laurent Saboret, 04/25/2013
