- To:
- Subject: Re: [cgal-discuss] AccessViolation Exception in surface generation
- Date: Fri, 19 Apr 2013 16:06:00 +0200
Hi Mario,
Please check if the same bug occurs with the examples provided with the surface reconstruction package (obviously using the same point set and the same parameters).
You may try the Surface Reconstruction demo pre-compiled for Windows:
This demo allows you do load point sets and run the Poisson Surface Reconstruction algorithm. You can also decimate point sets or compute normals.
Go to http://www.cgal.org/Manual/latest/doc_html/cgal_manual/packages.html. Download and unzip the "Demo: Surface Reconstruction" link.
You will need Qt 4. Qt 4 is free on Windows if you compile it by yourself.
Alternatively, you may compile surface_reconstruction_points_3/poisson_reconstruction_example.cpp command line example.
Best regards,
Laurent Saboret
Le 19/04/2013 10:34, mario a écrit :
Hi,
I am calling several time the Poisson surface reconstruction in my
application. Some times even with same point set my application crash with
this error "System.AccessViolation Exception: attempted to read or write
protected memory". Sometimes it happens and others time it's ok. It let me
think about not initialized pointers about poisson function.
I use CGAL 4.1 32 bit in windows builded with visualstudio 2010.
i tested my application in windows 7 32 and 64 bit editions.
I discovered that if i put my application setting to windowsxp compatibility
mode i solve and it never crashes!!
at this point this could already be a solution but could there be other
possibilities ?
Best Regards,
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/AccessViolation-Exception-in-surface-generation-tp4657227.html
- [cgal-discuss] AccessViolation Exception in surface generation, mario, 04/19/2013
- Re: [cgal-discuss] AccessViolation Exception in surface generation, Laurent Saboret, 04/19/2013
- [cgal-discuss] Re: AccessViolation Exception in surface generation, mario, 04/22/2013
- Re: [cgal-discuss] Re: AccessViolation Exception in surface generation, Laurent Saboret, 04/25/2013
