- To:
- Subject: Re: [cgal-discuss] Re: Bug report: Linear Cell Complex and Cell Attributes
- Date: Wed, 24 Apr 2013 22:03:00 +0200
Le 24/04/2013 21:47, Guillaume Damiand a écrit :
Le 24/04/2013 21:38, jdumas a écrit :
Well, in my case *all* my cells have an associated attribute, so I don't
really see how using Tag_true would allow me to optimize anything.
Because when dart support is enabled for i-attributes; you can iterate through i-attributes instead of iterating through darts which is more efficient to process i-cells.
Needless
to say, right now I'm working with Tag_true enabled until you find the time
to look into it.
I found the problem; but the trivial solution (add a void* pointer in attributes when dart support is disabled) is not satisfying. I am searching for a better patch...
I got it. Try the following patch and tell me.
Guillaume
Regards
Guillaume
Regards,
Jérémie.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Bug-report-Linear-Cell-Complex-and-Cell-Attributes-tp4657236p4657277.html
Guillaume DAMIAND
CNRS, LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
diff --git a/Combinatorial_map/include/CGAL/Cell_attribute.h b/Combinatorial_map/include/CGAL/Cell_attribute.h index 7cd6c2e..153c4f6 100644 --- a/Combinatorial_map/include/CGAL/Cell_attribute.h +++ b/Combinatorial_map/include/CGAL/Cell_attribute.h @@ -131,19 +131,19 @@ namespace CGAL { /// Increment the reference counting. void inc_nb_refs() - { ++mrefcounting; } + { mrefcounting+=4; } // 4 because this is the 3rd bit (ie 1<<2) /// Decrement the reference counting. void dec_nb_refs() { - CGAL_assertion( mrefcounting>0 ); - --mrefcounting; + CGAL_assertion( mrefcounting>3 ); + mrefcounting-=4; // 4 because this is the 3rd bit (ie 1<<2) } public: /// Get the reference counting. unsigned int get_nb_refs() const - { return mrefcounting; } + { return (mrefcounting>>2); } // >>2 to ignore the 2 least significant bits void * for_compact_container() const { return vp; }
- [cgal-discuss] Bug report: Linear Cell Complex and Cell Attributes, jdumas, 04/19/2013
- Re: [cgal-discuss] Bug report: Linear Cell Complex and Cell Attributes, Guillaume Damiand, 04/20/2013
- Re: [cgal-discuss] Bug report: Linear Cell Complex and Cell Attributes, Guillaume Damiand, 04/22/2013
- [cgal-discuss] Re: Bug report: Linear Cell Complex and Cell Attributes, jdumas, 04/23/2013
- Re: [cgal-discuss] Re: Bug report: Linear Cell Complex and Cell Attributes, Guillaume Damiand, 04/23/2013
- Re: [cgal-discuss] Re: Bug report: Linear Cell Complex and Cell Attributes, Guillaume Damiand, 04/24/2013
- [cgal-discuss] Re: Bug report: Linear Cell Complex and Cell Attributes, jdumas, 04/24/2013
