cgal-discuss - [cgal-discuss] Bug report: Linear Cell Complex and Cell Attributes
  • To:
  • Subject: [cgal-discuss] Bug report: Linear Cell Complex and Cell Attributes
  • Date: Fri, 19 Apr 2013 06:43:36 -0700 (PDT)
Hi.
I'd like to report what I think is a bug in the package Linear Cell Cemplex
form CGAL (either that, or I've missed something in the documentation, which
is very much possible). It happens when you try to define your own attribute
associated to an edge or another i-cell, with Tag set to CGAL::Tag_false,
and if you want to insert a new vertex along some edge.
Here is a link to a minimal example file, and the CMakeList.txt used to
compile it:
http://pastebin.com/Uj9698Tk
http://pastebin.com/66jWdP3x
The interesting thing is that it compiles fine in 'Release' mode, but if you
change CMAKE_BUILD_TYPE to 'Debug' (i.e. when you compile without -DNDEBUG),
then you will see a bunch of errors whose meaning elude me. And if you
change the Tag to CGAL::Tag_true, then it also compiles fine.
For the sake of completeness, here are the versions that I used:
- cgal 4.2
- gcc 4.7.2
- boost 1.53.0
- cmake 2.8.9
- gmp 5.1.1 / mpfr 3.1.1
- os : ubuntu quantal
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-report-Linear-Cell-Complex-and-Cell-Attributes-tp4657236.html
