cgal-discuss - Re: [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?
  • To:
  • Subject: Re: [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?
  • Date: Mon, 29 Apr 2013 15:22:09 +0200
The simplest but probably not the faster is to use Search_traits_adapter
with Search_traits_2 and a property map that creates 2D points on the
fly from 3D points.
You are right that [1] is longer to write but will be faster.
Sebastien.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_61.3.5
On 04/29/2013 03:11 PM, Matti Lehtonen wrote:
Hi,
what is the most efficient way to do nearest neighbourhood search among
3D points with a 2D distance (Z is ignored)? And unfortunately, the Z
component is needed after the nearest point is found, so pure 2D
solution is out of question :/
There seems to be several ways to do it, like
a)
CGAL::Search_traits<NT,Point,CartesianIterator,ConstructCartesianIterator,ConstructMinVertex,ConstructMaxVertex>
// Tree - 3D points used like 2D points
typedef CGAL::Search_traits<FT,
Multi_Classified_Point,
Multi_Classified_Kernel::Cartesian_const_iterator_2,
Multi_Classified_Kernel::Construct_cartesian_const_iterator_3>
MC_TreeTraits_2;
typedef CGAL::Orthogonal_incremental_neighbor_search<MC_TreeTraits_2>
MC_Neighbor_search_xy_2;
typedef MC_Neighbor_search_xy_2::Tree MCPointSet_xy_2;
except the distance calculation includes the Z component, like this test
case proves:
MCPointSet_xy_2 test;
Multi_Classified_Point test1 = Multi_Classified_Point(
ASPRS_Labels::NEVER_CLASSIFIED, 0.0, 0.0, 10.0 );
Multi_Classified_Point test2 = Multi_Classified_Point(
ASPRS_Labels::NEVER_CLASSIFIED, 1.0, 1.0, 10.0 );
Multi_Classified_Point test3 = Multi_Classified_Point(
ASPRS_Labels::NEVER_CLASSIFIED, 1.0, 1.0, 100000.0 );
test.insert( test1 );
test.insert( test3 );
MC_Neighbor_search_xy_2 nearest( test, test2 );
std::pair<Multi_Classified_Point,FT> const result =
*nearest.begin();
std::cerr << "Nearest point is <"
<< result.first.x() << ","
<< result.first.y() << ","
<< result.first.z()
<< "> for point <"
<< test2.x() << ","
<< test2.y() << ","
<< test2.z()
<< "> with distance of "
<< result.second
<< std::endl;
with output "Nearest point is <0,0,10> for point <1,1,10> with distance
of 2"
b) CGAL::Search_traits_adapter<Key,PointPropertyMap,BaseTraits> and
GAL::Distance_adapter<Key,PointPropertyMap,Base_distance>
How ever this approach seems to be used for points with coordinates
stored as tuples.
c) CGAL::Distance_xy_2<I>
Thought similar purpose like CGAL::Triangulation_euclidean_traits_xy_3,
except this one is undocumented and contain couple errors (reported by
GCC 4.7.2), like get_point(#) should be replaced with this->get_point(#)
and there are no search traits, which define "Point"
d) Example 61.3.5
Error prone, because quite lot of code must be copy & pasted.
Regards,
Matti L
Life is complex. It has real and imaginary parts.
