Re: [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?
- To:
- Subject: Re: [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?
- Date: Tue, 30 Apr 2013 16:55:57 +0200
On 04/30/2013 04:31 PM, Matti Lehtonen wrote:
Hi,It's not you who change it but each call to get(pmap,key). You must
On 30 April 2013 14:58, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
I think you should simply use:
struct Property_map_xy_2
typedef Point_2 value_type;
typedef value_type reference;
typedef const Multi_Classified_Point & key_type;
typedef boost::readable_property_map___tag category;
with
Property_map_xy_2::reference
get
Property_map_xy_2,
Property_map_xy_2::key_type p
return Point_2( p.x(), p.y() );
Without reference at "typedef value_type reference", but still with
const keyword, a core dump is created, while building the tree.
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: b = (b && (bbox.min_coord(i) <= tbox.min_coord(i)))
File: /usr/include/CGAL/Point_container.h
Line: 325
otherwise, you might use tmp while it was changed.
I used a const reference, so changing should not be possible.
remove this static variable.
If it still does not work please provide a minimal example showing the
pb, I'm quite sure there is no pb with the implementation.
Sebastien.
It seems that a tuple version works - inefficiently and with ugly code,
but it works.
To the wish list:
* e.g. CGAL::Distance_xy_3 could be used similarly like
CGAL::Triangulation_euclidean_traits_xy_3, which allows use of 3D points
for 2D triangulation
Matti L
Life is complex. It has real and imaginary parts.
- [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?, Matti Lehtonen, 04/29/2013
- Re: [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?, Sebastien Loriot (GeometryFactory), 04/29/2013
- Re: [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?, Matti Lehtonen, 04/30/2013
- Re: [cgal-discuss] Suggestions for how to do 2D nearest neighbour search from 3D points?, Sebastien Loriot (GeometryFactory), 04/30/2013
