- To:
- Subject: Re: [cgal-discuss] What type is subdomain_index?
- Date: Thu, 02 May 2013 11:31:23 +0200
Le mercredi 01 mai 2013 22:49:01 David Bernstein a écrit :
> In a cell in a c3t3 how should I use cell->set_subdomain_index()? What
> exactly is the argument of this function supposed to be? I've looked
> everywhere in the code but cannot find a type for the subdomain_index. If I
> just use an integer argument then strange things happen to the c3t3 object.
You are not supposed to call that function yourself. That function is called my the 3D mesh generator during the meshing process. When it returns, you can read the subdomain index using cell->subdomain_index(). The type Subdomain_index depends on the type of the domain.
Laurent Rineau, PhD
- [cgal-discuss] What type is subdomain_index?, David Bernstein, 05/02/2013
- Re: [cgal-discuss] What type is subdomain_index?, Laurent Rineau (CGAL/GeometryFactory), 05/02/2013
- Re: [cgal-discuss] What type is subdomain_index?, Mariette Yvinec, 05/02/2013
- [cgal-discuss] Re: What type is subdomain_index?, David Bernstein, 05/02/2013
