- To:
- Subject: Re: [cgal-discuss] What type is subdomain_index?
- Date: Thu, 02 May 2013 13:34:29 +0200
The type Subdomain_index is part of the Meshdomain_3 concept. It is therefore defined by the model of Meshdomain_3 that you are using. See http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3_ref/Concept_MeshDomain_3.html Le 02/05/13 11:31, Laurent Rineau
(CGAL/GeometryFactory) a écrit :
Le mercredi 01 mai 2013 22:49:01 David
Bernstein a écrit :
> In a cell in a c3t3 how should I use
cell->set_subdomain_index()? What
> exactly is the argument of this function
supposed to be? I've looked
> everywhere in the code but cannot find a
type for the subdomain_index. If I
> just use an integer argument then
strange things happen to the c3t3 object.
You are not supposed to call that function
yourself. That function is called my the 3D mesh generator
during the meshing process. When it returns, you can read the
subdomain index using cell->subdomain_index(). The type
Subdomain_index depends on the type of the domain.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
Release Manager of the CGAL Project
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] What type is subdomain_index?, David Bernstein, 05/02/2013
- Re: [cgal-discuss] What type is subdomain_index?, Laurent Rineau (CGAL/GeometryFactory), 05/02/2013
- Re: [cgal-discuss] What type is subdomain_index?, Mariette Yvinec, 05/02/2013
- [cgal-discuss] Re: What type is subdomain_index?, David Bernstein, 05/02/2013
