- To:
- Subject: [cgal-discuss] Re: Delaunay 3D: Get triangle with info in vertices.
- Date: Tue, 7 May 2013 16:48:19 -0700 (PDT)
Thank you, Sebastien!
I've successfully implemented my algorithm using locate() method. I get
Cell_handle from it and then iterate through vertices. In this case I have
an access to info() field. It works a lot faster!
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Delaunay-3D-Get-triangle-with-info-in-vertices-tp4657355p4657393.html
- [cgal-discuss] Delaunay 3D: Get triangle with info in vertices., Michael Kalygin, 05/04/2013
- Re: [cgal-discuss] Delaunay 3D: Get triangle with info in vertices., Sebastien Loriot (GeometryFactory), 05/06/2013
- [cgal-discuss] Re: Delaunay 3D: Get triangle with info in vertices., Michael Kalygin, 05/08/2013
