cgal-discuss - Re: [cgal-discuss] Re: Function of the area of a power cell with respect to weight
  • To:
  • Subject: Re: [cgal-discuss] Re: Function of the area of a power cell with respect to weight
  • Date: Mon, 13 May 2013 09:46:48 +0800
I've never thought about that. I'll try, thanks for your good suggestion.
On Mon, May 13, 2013 at 7:55 AM, 杨成林 <> wrote:
Why me? Your can discuss problems with the author of that paper.
在 2013-5-12 下午10:52,"Haibo Chen" <>写道:
Can you tell me how do you think about it? Just wanna check with you about my idea.
On Sun, May 12, 2013 at 10:13 PM, 杨成林 <> wrote:
I have found the paper you talked about. It described this problem clearly.
2013/5/12 liudaisuda <>
Yes exactly.  I am thinking to solve the equation V(si,wi) - ci = 0 for wi, I need to try different values of wi and compute the power diagram assuming all other site information is set constant. By try different values of wi, I mean something like newton's method could be used here to determine the next value of wi based on its current value. Say I start with wi = 0, then compute the power diagram and see how V(si, wi) - Ci behaves and choose the next value of wi making use of Newton's method. Do you think it is possible?
On Sat, May 11, 2013 at 9:53 PM, 杨成林 [via cgal-discuss] <[hidden email]> wrote:
If the change of the weight does not change the triangulation, the area can be formulated with the weight. But if the triangulation changes, this problem is very difficult.
2013/5/10 liudaisuda <[hidden email]>
I came across a function of the area of a power cell written in the form
V(Si,Wi) in a paper (Si is the position of a point and Wi is the weight
given to that point). The paper is about capacity-constrained power diagram.
My ultimate goal is to find the root Wi of the equation V(Si,Wi) - Ci = 0,
in which Ci is given as the capacity of that point. But I have no idea in
what the explicit form the function V(Si,Wi) is with respect to Wi. Any help
would be highly appreciated.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Function-of-the-area-of-a-power-cell-with-respect-to-weight-tp4657404.html
杨成林
Yang Chenglin
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Function-of-the-area-of-a-power-cell-with-respect-to-weight-tp4657404p4657408.html
To unsubscribe from Function of the area of a power cell with respect to weight, click here.
NAML
View this message in context: Re: Function of the area of a power cell with respect to weight
杨成林
Yang Chenglin
