cgal-discuss - Re: [cgal-discuss] segment_3 sphere intersection
  • To:
  • Subject: Re: [cgal-discuss] segment_3 sphere intersection
  • Date: Tue, 14 May 2013 17:40:02 +0200
On 05/14/2013 05:13 PM, mriem wrote:
Hello
I was looking into the CGAL intersections utilities at
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_intersection.html
and I could not find a segment_3 sphere intersection.
It is inside "With the 3D Spherical Kernel", because you need a Kernel
which is a Spherical_kernel [1].
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Circular_kernel_3/Chapter_main.html#chapter-spherical-kernel
I have tried to implement the example code from that page
#include<CGAL/intersections.h>
void foo(CGAL::Segment_2<Kernel> seg, CGAL::Line_2<Kernel> line)
CGAL::Object result = CGAL::intersection(seg, line);
if (const CGAL::Point_2<Kernel> *ipoint =
CGAL::object_cast<CGAL::Point_2&lt;Kernel> >(&result)) {
// handle the point intersection case with *ipoint.
} else
if (const CGAL::Segment_2<Kernel> *iseg =
CGAL::object_cast<CGAL::Segment_2&lt;Kernel> >(&result)) {
// handle the segment intersection case with *iseg.
} else {
// handle the no intersection case.
changing function arguments
seg to type
CGAL::Segment_3<Kernel>
and line to
CGAL::Sphere_3<Kernel>
but the linker complains there is no such specialization for that templated
function.
Can I do segment_3 to sphere intersection?
Thank you very much.
Miguel Oliveira
PS: in fact, for this particular case, I only needed a do_intersect
functionality, but I think that if a do_intersect exists, so will the
intersect.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/segment-3-sphere-intersection-tp4657426.html
