- To:
- Subject: Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
- Date: Tue, 14 May 2013 17:37:06 +0200
On 05/14/2013 05:11 PM, placebo wrote:
Sebastien,
Indeed, using "Simple_cartesian" or
"Exact_predicates_inexact_constructions_kernel" allows me to find correct
NUMBER of intersections, BUT these kernels do not correctly return WHAT KIND
of intersections they are (i.e. Point, Segment, etc.). I have to use
"Exact_predicates_EXACT_constructions_kernel" if I want that information.
Does this sound right to you?
Do you need to construct the point or do you only need to know what is the type of the intersection?
If you only need the type there might be a cheaper solution. If you need
an exact construction then it is different.
Sebastien.
Willie B. Maddox Ph.D.
Physicist / Senior Systems Modeler
Science Applications International Corporation
Huntsville, AL USA
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/triangle-query-to-AABB-triangle-tree-returns-incorrect-intersection-objects-tp4657400p4657425.html
- [cgal-discuss] triangle_query to AABB_triangle_tree fails., placebo, 05/09/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree returns incorrect intersection objects, placebo, 05/09/2013
- Re: [cgal-discuss] triangle_query to AABB_triangle_tree fails., Philipp Moeller, 05/10/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/13/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/14/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/14/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/15/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., ChaoM, 05/14/2013
