- To:
- Subject: [cgal-discuss] Re: 3d mesh density issue
- Date: Thu, 16 May 2013 04:06:25 -0700 (PDT)
Well, I think you are talking about different thing:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html
I already have shell object and I'm creating 3D mesh from it (as topic
says):
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.html
I still need help with reducing mesh density. Another example. This:
connections_beam.off
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/connections_beam.off>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/beam_in.png>
is turn into this:
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/beam.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/beam2.png>
I need to reduce density. Please, help.
Regards
Marek
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3d-mesh-density-issue-tp4657448p4657462.html
- [cgal-discuss] 3d mesh density issue, Marek, 05/15/2013
- [cgal-discuss] Re: 3d mesh density issue, ChaoM, 05/15/2013
- [cgal-discuss] Re: 3d mesh density issue, Marek, 05/15/2013
- [cgal-discuss] Re: 3d mesh density issue, ChaoM, 05/16/2013
- [cgal-discuss] Re: 3d mesh density issue, Marek, 05/16/2013
- Re: [cgal-discuss] Re: 3d mesh density issue, t.doehring, 05/16/2013
