- To:
- Subject: Re: [cgal-discuss] Re: 3d mesh density issue
- Date: Thu, 16 May 2013 10:59:41 -0400
Hi Marek,
I'm not an expert on polyhedral surface meshing, but i'm well versed in volumetric meshing with CGAL and meshing in general.
Looking at your model and mesh, I don't think you will be able to reduce mesh density very much using tets in CGAL.
You basically have single element thickness already. Tet meshing of thin shells is a challenging problem. Also, depending on your application, tet shells are really lousy for FE analysis due to the 'locking' problem.
You need to use a 'non-locking' tet element, I think that Abaqus has one.
As far as I know, CGAL places high priority on edge/surface tolerance. In the volumetric mesher, this is a parameter that you can adjust. Reducing the tolerance allows coarser meshes. I don't know how or if you can do this with the polyhedral mesher. It kind of doesn't make sense to inaccurately mesh a polyhedral surface... kind of defeats the purpose especially in your case where you have pretty strict boundary requirements.
Hope that helps.
Todd Doehring, Ph.D.
Research Assistant Professor
School of Biomedical Engineering, Science, and Health Systems
Drexel University
and CEO: Tensor Biotechnologies LLC (Tensortek.com)
On Thu, May 16, 2013 at 7:06 AM, Marek <> wrote:
Well, I think you are talking about different thing:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html
I already have shell object and I'm creating 3D mesh from it (as topic
says):
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3/Chapter_main.html
I still need help with reducing mesh density. Another example. This:
connections_beam.off
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/connections_beam.off>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/beam_in.png>
is turn into this:
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/beam.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657462/beam2.png>
I need to reduce density. Please, help.
Regards
Marek
View this message in context: http://cgal-discuss.949826.n4.nabble.com/3d-mesh-density-issue-tp4657448p4657462.html
- [cgal-discuss] 3d mesh density issue, Marek, 05/15/2013
- [cgal-discuss] Re: 3d mesh density issue, ChaoM, 05/15/2013
- [cgal-discuss] Re: 3d mesh density issue, Marek, 05/15/2013
- [cgal-discuss] Re: 3d mesh density issue, ChaoM, 05/16/2013
- [cgal-discuss] Re: 3d mesh density issue, Marek, 05/16/2013
- Re: [cgal-discuss] Re: 3d mesh density issue, t.doehring, 05/16/2013
