cgal-discuss - Re: [cgal-discuss] Re: Divide by Zero in AABB tree
  • To:
  • Subject: Re: [cgal-discuss] Re: Divide by Zero in AABB tree
  • Date: Mon, 20 May 2013 12:58:00 +0200
Which version of CGAL are you using?
Could you restrict MPI to use only one thread to (be sure it is related)?
Sebastien.
On 05/19/2013 07:30 PM, schrodingersnewcat wrote:
It's been a little while. Now that finals are over I'm back to debugging
this issue.
I'm attaching 4 back traces. There are four nodes in my MPI program, each
fails on the same call, but it looks like the back trace is slightly
different, especially for node 0.
I hope this helps. Please let me know if I can provide anything else to
figure this out.
node-0<http://cgal-discuss.949826.n4.nabble.com/file/n4657500/node-0>
node-1<http://cgal-discuss.949826.n4.nabble.com/file/n4657500/node-1>
node-2<http://cgal-discuss.949826.n4.nabble.com/file/n4657500/node-2>
node-3<http://cgal-discuss.949826.n4.nabble.com/file/n4657500/node-3>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Divide-by-Zero-in-AABB-tree-tp4657026p4657500.html
