cgal-discuss - [cgal-discuss] Re: Tetrahedral mesh point location
  • To:
  • Subject: [cgal-discuss] Re: Tetrahedral mesh point location
  • Date: Wed, 22 May 2013 05:11:28 -0700 (PDT)
Thanks for pointing that out. I'm finding my way around the documentation
better now.
Can you tell me if there's a straightforward way to return the "global
vertex indices" of tetrahedron in a Delaunay triangulation. I.e., if I make
a Delaunay triangulation, I can find the tetrahedron containing a point
using locate(). Then I can access the vertices via the cell handle and
return the point coordinates and LOCAL cell indices (1,2,3,4). It would also
be useful to return which point each vertex of a cell corresponds to in the
GLOBAL list of points that were inserted into the Delaunay triangulation.
In the attached file, I've written a short program that does what I want,
but I have to loop through the entire list of Delaunay points to find a
match to each cell vertex - surely there must be a more efficient way? Have
I overlooked a simple access function?
delaunay_cell_finder.cpp
<http://cgal-discuss.949826.n4.nabble.com/file/n4657556/delaunay_cell_finder.cpp>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Tetrahedral-mesh-point-location-tp4655387p4657556.html
