- To:
- Subject: Re: [cgal-discuss] Re: Tetrahedral mesh point location
- Date: Wed, 22 May 2013 16:16:06 +0200
A popular solution to your problem is to store in each triangulation vertex the global index of the point corresponding to that vertex. This is easily done using Triangulation_vertex_base_with_info as basis for the triangulation vertex class. See examples in sections 5.6, 5.7 and 5.8 of the user manual. Le 22/05/13 14:11, wallace a écrit :
Thanks for pointing that out. I'm finding my way around the documentation better now. Can you tell me if there's a straightforward way to return the "global vertex indices" of tetrahedron in a Delaunay triangulation. I.e., if I make a Delaunay triangulation, I can find the tetrahedron containing a point using locate(). Then I can access the vertices via the cell handle and return the point coordinates and LOCAL cell indices (1,2,3,4). It would also be useful to return which point each vertex of a cell corresponds to in the GLOBAL list of points that were inserted into the Delaunay triangulation. In the attached file, I've written a short program that does what I want, but I have to loop through the entire list of Delaunay points to find a match to each cell vertex - surely there must be a more efficient way? Have I overlooked a simple access function? delaunay_cell_finder.cpp <http://cgal-discuss.949826.n4.nabble.com/file/n4657556/delaunay_cell_finder.cpp> -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Tetrahedral-mesh-point-location-tp4655387p4657556.html Sent from the cgal-discuss mailing list archive at Nabble.com. -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Re: Tetrahedral mesh point location, wallace, 05/07/2013
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Andreas Fabri, 05/07/2013
- [cgal-discuss] Re: Tetrahedral mesh point location, wallace, 05/22/2013
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Mariette Yvinec, 05/22/2013
