- To:
- Subject: 回复: [cgal-discuss] Informations about Nearest Neighbour
- Date: Fri, 24 May 2013 07:35:00 +0800
v
孙树立
----- Reply message -----
发件人: "Sebastien Loriot (GeometryFactory)" <>
收件人: <>
主题: [cgal-discuss] Informations about Nearest Neighbour
日期: 周四, 5 月 23 日, 2013 年 6:17 下午
On 05/23/2013 12:04 PM, Rasael Bervini Monkow wrote:
> Il 23.05.2013 07:12, Sebastien Loriot (GeometryFactory) ha scritto:
>> On 05/23/2013 07:11 AM, Sebastien Loriot (GeometryFactory) wrote:
>>> On 05/22/2013 02:19 PM, wrote:
>>>> Hi,
>>> You are on a mailing to help user of the CGAL library.
>>> You will have chances to get an answer on a Matlab list.
>> ... more chances ...
>> PS: I saw a message on the bindings list for which you got answer but
>> no feedback from you. What did not work?
>>> Sebastien.
> Thank you for your answer. Since MatLab uses CGAL I preferred to come
> and ask directly to the source, also an answer would be probably easier
> to get thru an open source project rather than in a commercial product.
> However I will try to ask there aswell.
> Regarding the message on the bindings, I had no idea on how to compile,
> the step-by-step guide doesn't really explain what to do if you don't
> know the tools (I am still at the first step, cmake configuration) and
> the first answer was that it requires a steep learning curve. I only
> need a single functionality and I don't see the need to learn the whole
> compiling process.
> And since there is no compiled version I understand I have to compile it
> myself depending on the system I'm working on, and that's not a possible
> option for me.
step 1: install CGAL following [1]
(no need for QT, Qglviewer)
step 2: click on cmake executable, open the CMakeLists.txt of the bindings, configure the option according to [2] after a first click on
configure.
then configure again and generate.
Then open the .sln with visual and compile it.
> Thank you
> Rasael
> PS. Is there by any chance a java-bindings precompiled library for x86
> (possibly x64) and MacOSX of any stable version of the bindings that
> supports triangulation and nearest neighbor?
It's really a pain to maintain, or it would need to setup a build-bot.
So except if someone pays for it, I won't do it.
[1] http://www.cgal.org/windows_installation.html
[2] http://code.google.com/p/cgal-bindings/wiki/Installation
- 回复: [cgal-discuss] Informations about Nearest Neighbour, , 05/24/2013
