cgal-discuss - Re: [cgal-discuss] difficulties with clang and c+11
  • To: Ruud Vlaming <>
  • Cc:
  • Subject: Re: [cgal-discuss] difficulties with clang and c+11
  • Date: Thu, 23 May 2013 15:12:12 +0200
Ruud Vlaming
writes:
> On 22-05-13 22:03, Marc Glisse wrote:
>> On Wed, 22 May 2013, Ruud Vlaming wrote:
>>> There seems to be unknown symbols called from CGAL, but also from
>>> other object files. What is causing this is not clear to me yet. The
>>> question is of course, is this still a CGAL problem? If not, i should
>>> not bother you with this, i guess.
>> Are you sure the various libraries (CGAL, boost, etc) were all compiled
>> with clang using the same -stdlib option?
> No, i am not, for i did not compile these libs by
> hand (macports did). I assumed the make script would
> take care of incompatibilities if needed. If this is not
> the case, it is going to pose a problem, for other
> programs may require libraries files with other
> compiler switches again.
Binary incompatibility between C++11/C++03 code is a really difficult
problem to solve in a build system, especially when you rely on some
automated packaging system to make choices for you.
> It seems i must use local copies of all dependencies,
> and compile them separately. Hmm, this is going to
> take much more time than anticipated ...
Not necessarily. You can instruct MacPorts to always pass -std=c++11
through the configure.cxxflags [1] option and go for a full rebuild of
the dependencies. You can also use this to ensure the correct stdlib
option is set.
> What is the standard way of handling this? Up to now
> i did not have any problems when using for example
> boost and c++11.
Most of Boost is not compiled, but you will already run into problems
when trying to link against Boost.FileSystem [2].
Footnotes:
[1] http://guide.macports.org/#reference.phases.configure
[2] https://svn.boost.org/trac/boost/ticket/6779
