- To:
- Subject: Re: [cgal-discuss] Re: Nef polygon
- Date: Fri, 24 May 2013 07:17:35 +0200
On 05/24/2013 06:17 AM, ChaoM wrote:
Hello Sebastien:
These days ,I try to use the Convex_Hull_3 to check my polyhedron.
Before I use it ,there are 360 points in the polyhedron. After that,there
exits 325 points. And ,should I also give the insex of points to the Convex
too?
After using the Convex ,I try to use the Nef union, but there is a
error that "CGAL precondition is simple()"? Do you have any idea to solve
it ?
Thanks !
As this point, you should post your code with the input points because it seems we don't understand each other.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-tp4657453p4657574.html
- Re: [cgal-discuss] Re: Nef polygon, (continued)
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/20/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/21/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/22/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/24/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/24/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/26/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/29/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/30/2013
