- To:
- Subject: [cgal-discuss] Re: Nef polygon
- Date: Mon, 20 May 2013 17:06:17 -0700 (PDT)
Thanks for quick reply~
Firstly, I compute two intersected half spheres :which both of them are
in orders. When I directly convert them into nef, the result of .off seems
good !
But I should compute outsude points and intersected points of two half
spheres . So I partly do the Delaunay Triangulation for each outside an d
intersected points. And I want to union two parts,so I want to use the
Nef~~But after I do Delaunay, the convertaion of Delaunay to .off seems bad
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-tp4657453p4657521.html
- Re: [cgal-discuss] Re: Nef polygon, (continued)
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/16/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/16/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/17/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/17/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/20/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/20/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/21/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/22/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/24/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/24/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/26/2013
