- To:
- Subject: [cgal-discuss] Re: question about running cgal example in qt-creator.
- Date: Mon, 3 Jun 2013 20:21:31 +0800
Dear all
I use QT Creator 2.4.1 as my IDE, and my system is Ubuntu 12.04 amd 64. My CGAL version is 4.2. When I run the example of CGAL/exmaple/Mesh_3/mesh_polyhedral_domain_with_features.cpp in QT Creator, I meet such a problem:
Starting /home/huayiwei/work/program/meshGenerator/example/Regular_triangulation/Mesh_3/build/mesh_polyhedral_domain_with_features...
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: !empty()
File: /usr/local/include/CGAL/AABB_tree.h
Line: 152
The program has unexpectedly finished.
Expr: !empty()
Line: 152
But I can run the compiled program directly in my bash shell and get the result mesh. Did anyone ever meet the same problem? Please help, thanks a lot.
Best
Huayi
2013/6/3 魏华祎 <>
Dear all
Expr: !empty()
Line: 152
%%%%%%%%%%%%%%%But I can run the compiled program directly in my bash shell and get the result mesh. Did anyone ever meet the same problem? Please help, thanks a lot.BestHuayi
# This is the CMake script for compiling a CGAL application.
project( Mesh_3_example )
cmake_minimum_required(VERSION 2.6.2)
if("${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}"
VERSION_GREATER 2.8.3)
cmake_policy(VERSION 2.8.4)
else()
cmake_policy(VERSION 2.6)
endif()
add_definitions(-DCGAL_MESH_3_NO_DEPRECATED_SURFACE_INDEX
-DCGAL_MESH_3_NO_DEPRECATED_C3T3_ITERATORS)
if ( MESH_3_VERBOSE )
add_definitions(-DCGAL_MESH_3_VERBOSE)
endif()
find_package(CGAL COMPONENTS ImageIO)
if ( CGAL_FOUND )
include( ${CGAL_USE_FILE} )
find_package(Boost)
if ( Boost_FOUND AND Boost_VERSION GREATER 103400 )
include( CGAL_CreateSingleSourceCGALProgram )
# Compilable examples
# create_single_source_cgal_program( "mesh_implicit_sphere.cpp" )
"mesh_implicit_sphere_variable_size.cpp" )
"mesh_two_implicit_spheres_with_balls.cpp" )
# create_single_source_cgal_program( "mesh_implicit_domains.cpp"
"implicit_functions.cpp" )
# create_single_source_cgal_program( "mesh_polyhedral_domain.cpp" )
"mesh_polyhedral_domain_with_features.cpp" )
"mesh_polyhedral_implicit_function.cpp" )
"mesh_polyhedral_surface_tolerance_region.cpp" )
"mesh_polyhedral_edge_tolerance_region.cpp" )
else()
message(STATUS "NOTICE: This program requires Boost >= 1.34.1, and will
not be compiled.")
endif()
else()
message(STATUS "This program requires the CGAL library, and will not be
compiled.")
endif()
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Mesh_triangulation_3.h> #include <CGAL/Mesh_complex_3_in_triangulation_3.h> #include <CGAL/Mesh_criteria_3.h> #include <CGAL/Polyhedral_mesh_domain_with_features_3.h> #include <CGAL/make_mesh_3.h> // Domain typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Polyhedral_mesh_domain_with_features_3<K> Mesh_domain; // Triangulation typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr; typedef CGAL::Mesh_complex_3_in_triangulation_3< Tr,Mesh_domain::Corner_index,Mesh_domain::Curve_segment_index> C3t3; // Criteria typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria; // To avoid verbose function and named parameters call using namespace CGAL::parameters; int main() { // Create domain Mesh_domain domain("data/fandisk.off"); // Get sharp features domain.detect_features(); // Mesh criteria Mesh_criteria criteria(edge_size = 0.025, facet_angle = 25, facet_size = 0.05, facet_distance = 0.005, cell_radius_edge_ratio = 3, cell_size = 0.05); // Mesh generation C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria); // Output std::ofstream medit_file("out.mesh"); c3t3.output_to_medit(medit_file); }
- [cgal-discuss] Re: question about running cgal example in qt-creator., 魏华祎, 06/03/2013
- Re: [cgal-discuss] Re: question about running cgal example in qt-creator., Laurent Rineau (CGAL/GeometryFactory), 06/03/2013
- Re: [cgal-discuss] Re: question about running cgal example in qt-creator., 魏华祎, 06/04/2013
- Re: [cgal-discuss] Re: question about running cgal example in qt-creator., 魏华祎, 06/05/2013
- Re: Re: [cgal-discuss] Re: question about running cgal example in qt-creator., Laurent Rineau (CGAL/GeometryFactory), 06/05/2013
